Remove rear axle on D
HWess
01-02-2007 16:31:44
Need to replace rear axle seal on D. Hub is part of the axle so entire axle must come out. Left one came easy. Have big nut off right one and sprocket is loose but can't get axle out. Inside bearing must come off axle to let axle come out. Won't budge. Any suggestions?
dctom
01-02-2007 17:05:49
 Re: Remove rear axle on D in reply to HWess, 01-02-2007 16:31:44
HERB, YOU MAY HAVE TO PUT THE OTHER AXLE BACK IN THAN USE THE BIG NUT TO PUSH THE AXLE OUT THE TWO AXLES ARE SO CLOSE TO GEATHER THAT THE NUT HAS TO PUSH THE AXLE OUT, I KNOW NOT VERY CLEAR BUT MAYBE YOU CAN FIGURE OUT WHAT I AM TRYING TO SAY I HAVE DONE IT THAT WAY MANY TIMES ALWAYS ONE OF THEM DONT WANT TO MOVE TOM
