Approx Weight Footprint/Size of a Case 222
n2deep
01-02-2007 14:22:43
Just bought a baby Case (Model 222) to mow around the yard/keep the others company.. Does anyone know the approx weight with the mower deck and the width of the mower at it's widest part (the deck)? Just trying to figure out if it will fit in the ranger or do I need to get out the ole trailer
Thanks
iluvcase
01-02-2007 19:49:03
 Re: Approx Weight Footprint/Size of a Case 222 in reply to n2deep, 01-02-2007 14:22:43
You're going to be under 900 lbs. total weight.I do'nt know what size mower deck you have....i believe they could be had with 38-44-or 48" decks. I would get out the trailer....it's too wide for a ranger....unless you take the deck off first. I have an old 444 with a 48" deck and hyd. lift....with 4 cast iron wheel weights on the rear..... I scaled it and it weighs in at 980 lbs. On my 444 the frt. wheel tread is 33 1/2" and the rear tread is 31 1/2". Overall length is 70". These figures should help you out.....Good luck with your little "Case"
n2deep
01-03-2007 06:44:43
 Re: Approx Weight Footprint/Size of a Case 222 in reply to iluvcase, 01-02-2007 19:49:03
Thanks for the assist
