Crossmotor Base gasket?
cory scharf
01-02-2007 10:41:14
In an 18-32,when setting the block onto the frame,do i have to use a gasket for a spacer or can i use silicone?
Brian in Ohio
01-02-2007 11:26:45
 Re: Crossmotor Base gasket? in reply to cory scharf, 01-02-2007 10:41:14
I was with a club that restored a 10-18 a few years back.
If memory serves me, I think we cut a gasket for the block. We didn't use very thick material, just enough to ensure it was sealed. We just turned the top half of the block upside down, taced it out, and tap out the edges with a ball peen hammer.
I don't know if that would be the same for a 18-32, but I wouldn't think they would be that much different.
Bobcat
01-02-2007 18:55:12
 Re: Crossmotor Base gasket? in reply to Brian in Ohio, 01-02-2007 11:26:45
I had a very thin gasket .015? on a 12-20. I cut a new one out of the thinnest sheet I could find. The camshaft to crank gear clearance was close when I disassembled so I did not want to be any closer than it was already.
