TCH fluid
Animal
01-02-2007 08:20:19
I have been working on this 930 standard with an over center clutch, the manual calls for TCH fluid, must I get this from Case I H or is their after market oils, what do you guys suggest? Thanks.....
Tom Huston
01-02-2007 18:09:50
 Re: TCH fluid in reply to Animal, 01-02-2007 08:20:19
TCH is still available from Case dealers. Most ag dealers just stock hytran. We still have a few pails of TCH left in stock. We mostly sell hytran. Now I thought the clutch was oiled from the engine just as the older Case tractors or did they change that once they went to the 8 speed trany.
caseman-d
Don in Tebbetts
01-02-2007 14:52:21
TCH has been replaced by HY-TRAN
R Wyler
01-02-2007 12:24:56
If your CIH dealer doesnt stock it you should be able to get it at a CASE industrial equipment dealer I believe that is the hyd oil they use for there industrial line.
dboll
01-02-2007 11:47:55
I have found case is not much higher than generics so I buy Case oils for the high dollar equipment, TCH-transmission, clutch, hydraulic
CENTAUR
01-02-2007 09:45:06
Type in TCH fluid in into GOGGLE or? I just did it & the answer is there.CENTAUR
dboll
01-02-2007 12:00:18
 Re: TCH fluid in reply to CENTAUR, 01-02-2007 09:45:06
I haven't seen a Union 76 station for so long I didn't know they were still in business!!
