identify Case SC
heenk
01-01-2007 12:56:07
I have a case #317645 SC
Looking in a book for specs of the different models two of the colums one reads S and the other C. My SC I always thought that the S stands for single wheel although I have a row crop. But should I look under the S or C it makes a different on the valve cap settings.
C. Amick
01-02-2007 10:07:31
 Re: identify Case SC in reply to heenk, 01-01-2007 12:56:07
I believe the exhaust and intake valve clearance on the "S" Series tractors is 0.010" cold. Is that what the book shows under the "S" column? The "S" is the standard wide front model. The SC is a row crop tractor(The narrow front can either be double or single wheel). The SO is an orchard and the SI is an industrial tractor.
John Noname
01-01-2007 14:44:23
You are missing the first number of the serial number. If you are looking at the plate on the dash the first number may be messed up by the screw head. If you can't read it the serial number is also on the block, left side where it bolts to the transmission housing. This maybe why you are having difficulty finding information.
S is a model of the SC family. Fixed wide front end. Same engine as the SC. The was the S, SC-3, SC-4, SO, and the ones, not many that ended in EX which were designated for export. If you are looking for info under C you would most likely find info for the model C which was replaced by the DC. Hope this helps a little.
