vac engine backfires and stops sometimes
bob in missouri
12-31-2006 03:46:35
vac starts and runs pretty good but will from no apparant reason will backfire loud sometimes and will die other times it will keep running have put plugs and points condencer rotor cap any ideas would be welcome most times will restart pretty quick and run pretty good for a while
arthur
01-03-2007 09:26:11
 Re: vac engine backfires and stops sometimes in reply to bob in missouri, 12-31-2006 03:46:35
Check the plug wires...have to be solid copper core wires....If they are the silicone ones, will cause all kinds of funky problems like that....
buckshott
12-31-2006 06:09:36
Dirty Carb. Had same problem with my Oliver.
Clean carb and adjust main jet
Gene Dotson
12-31-2006 05:14:13
Bob;
Sounds like you have an intake valve sticking open occasionally... Gene
