eagle to 3 pt?
j stice
12-29-2006 23:31:17
hello all, since my vac has no lower or middle parts of the eagle hitch, and i cannot seem to locate same, maybe im going the wrong way with this. i would think that after aquiring the orig pcs i would be trying to convert ends to 3 pt anyway. is there some slightly later arms and intermediates with adjuster 1 side that they progressed to after 56vac ended?
thanks for advice!
mj
12-30-2006 20:24:23
 Re: eagle to 3 pt? in reply to j stice, 12-29-2006 23:31:17
third party image
Just make up what you need with iron from the steel yard and links and ball ends from Speeco or some such.
Ted Olbrich
12-30-2006 05:14:46
They are not hard to covert if you can find the parts. Go to any TSC, Farm & Fleet, or similar store, and get a set of cat.#1 lift arms. You may have to drill some holes, but they are not a hard adaptation. You will need a set of Ford, Fergeson, or any other small tractor with three point, to get the adjustment link and the fixed link. They need the double swivel. That's the problem with eagle hitch. They didn't move wnen a rock came along. LOL!
