VAC Marriage
Olddog
12-29-2006 16:08:09
Have a post 560000 51 VAC back half (torque tube, tranny and diff) with Eagle Hitch that I would like to marry to a complete, running, 46', to include motor, ft bolster, steering gear, tank and all tin work. Anyone done this? Some issues are; suction to the pump out of the torque tube using the OLD steering gear with chicken roost linkage. Hood shorter? Newer tractor had taller tires; will it have lower gearing? Also want to use the pully pump as well as the engine hyd pump. (For different things). Am i nutz? Commence shooting. Me thankyerbellymuch
mj
12-29-2006 16:14:05
 Re: VAC Marriage in reply to Olddog, 12-29-2006 16:08:09
Go for it. You can use a tee on the torque tube drain plug to get your pump intake.
olddog
12-30-2006 13:53:29
 Re: VAC Marriage in reply to mj, 12-29-2006 16:14:05
Yeah!! Then mebbe solder a standpipe into a St Tee, so's it won't suck directly off the bottom. Thanks for the idea.
mj
12-30-2006 20:28:45
 Re: VAC Marriage in reply to olddog, 12-30-2006 13:53:29
If you used a reducer instead of a plug in the bottom you could put a short nipple up into the torque tube and another one into the tee. Might have to braze them to the reducer.
