Case AC 5350692 PLEASE help.
mikeinAZ
12-28-2006 21:43:19
please tell me all you can about this tractor. I just bought it, and have not idea what hp the engine is, or if I can find parts. Impulse buy, hoping not to regret. It also needs a front tire,"numbers on tire arent' there. If you can tell me what size to get that would be helpful. Thanks a ton.
Joe (Wa)
12-29-2006 00:54:02
 Re: Case AC 5350692 PLEASE help. in reply to mikeinAZ, 12-28-2006 21:43:19
Tractor is probably a model VAC, look for a V stamped to the left of the AC, may be partially under the tag screw. Serial nr is 1949 model year.
Case built 124 cid engine, rated about 21 hp pto and about 17 hp drawbar.
Original front tires were generally 5.00-15 to 6.00-16.
Joe
mikearizona
12-29-2006 10:06:37
 Re: Case AC 5350692 PLEASE help. in reply to Joe (Wa), 12-29-2006 00:54:02
Thank you very much for the information. It will be great help. I did find the V under the screw. Helps to know what your looking for.
