case se tractor
Scott Yates
12-27-2006 15:53:35
I own a Case se tractor serial number 5331703SE. I can find no information on this type of tractor. Can you help me?
Buckeye
12-27-2006 18:16:38
 Re: case se tractor in reply to Scott Yates, 12-27-2006 15:53:35
You might want to look at the tag more closely. I bought an SO tractor a few years ago off the ytmag classifieds. I asked the fellow to send me some pictures and the serial number. The model was an SOE and it wasn't until I went to pick it up that I discovered that there was also an X after the SOE. He didn't see it when he wrote the model number down because it was in the black part of the tag. Four SOEX's(exports) were sent to Traverse City, Michigan, so it is possible that you may have an S-export(board won't let me write the model designation!). Three of the four SOEX's are known to still exist. Mine and another collector has two. Is your tractor a standard or row crop?
CLIFF S
12-28-2006 17:30:47
 Re: case se tractor in reply to Buckeye, 12-27-2006 18:16:38
Theres a SOEX in central PA thats in the middle of being restored and it will be as nice as they get soon!
Buckeye
12-29-2006 05:30:58
 Re: case se tractor in reply to CLIFF S, 12-28-2006 17:30:47
CLIFF S, Do you know the serial number? Mine is 5309376. I think the one of the four missing is the next one after mine, # 5309377. As far as I know, #'s 78 and 79 are still in MI. It would be interesting to know if the one in PA is one of the four or if maybe others exist.
watsonsgotit
12-27-2006 16:07:22
You may ought to check the serial number on the tag versus the engine bell housing. S is the series. E stands for engine. That would be a power unit not a tractor. You probably have a SC. The engine could have been changed at some point. A SE engine would bolt into a SC tractor and visversa. From the serial number provided it should be a 49 model. In 49 I believe the Hydraulic pump was standard and the tractor would have either had a bail to lift cultivators or a set of remotes.
watsonsgotit
12-27-2006 16:06:01
