case model 31 backhoe up down slowly sinks
john mchugh
12-27-2006 15:12:57
when i lift the bucket all the way up it slowly falls back down again would that be a problem in the valve
Phil (NJ,Az,Sask)
12-27-2006 15:57:44
 Re: case model 31 backhoe up down slowly sinks in reply to john mchugh, 12-27-2006 15:12:57
John, It could be the cylinder piston seals or the valve. I have not changed the seals in that Big/Long sucker. The upper pivot point is inside the frame which makes it harder to use the hoe
as a work bench.
I work on the cylinders with them on the hoe,hoses connected. I just remove the pin on the END with the big Jam nut and using a pIN Spanner unscrew that nut. I then pull (come-along) Piston Rod shaft from the cylinder. I then reconnect the Pin I removed to the now free Piston rod shaft. This holds the piston rod so you can unscrew the end NUT (very tight) and the piston & big Jam nut come of the shaft. You can then replace the seals. Re assemble in reverse making sure piston shaft end nut is very tight.
BTW: my hoe has chains on the main boom such that
is stays UP when not digging or parked.
Hope this helps,
