VAC-14 engine swap
TimBinWV
12-27-2006 14:32:32
Can someone tell me if the engine from a 311b,1958 model,148 cu. in. will fit in the Vac-14? The VAC is a 56 model. Thanks a lot!
JMY
12-28-2006 12:49:00
 Re: VAC-14 engine swap in reply to TimBinWV, 12-27-2006 14:32:32
I am sure the engines will exchange with each other except the exhaust manifold. The two manifolds are different. The 311b should have the ability to go up or down. The port that goes out the top takes a elbow that has holes that sit at a 45% angle to top of the manifold. The Vac has an elbow that the holes are horizontal or parallel with manifold. The fly wheels are the same the water pumps are the same. Hope this helps.
TimBinWV
12-28-2006 16:01:43
 Re: VAC-14 engine swap in reply to JMY, 12-28-2006 12:49:00
Thanks,JMY. I hope it'll fit. I'm thinking the VAC needs a new bottomend,and I happen to have one. I hope the head will fit from the VAC engine to the 311b...
MIKES600
12-29-2006 17:54:59
 Re: VAC-14 engine swap in reply to TimBinWV, 12-28-2006 16:01:43
tHE HEAD WILL FIT FINE. I used one in my Vac puller.
