vac-14 clutch stuck
j stice
12-27-2006 08:04:15
happy holidays all!
i DROVE the little guy today!, the clutch is stuck tho i drove around the field uphill with brakes applied ,etc,etc, is there a good remedy for this?I am disabled to the point where splitting unit days are over.
I redid the "redo" carb myself and liberated the power nozzle and she worked!.meanwhile, still looking for lower eagle arms and the vertical intermediate pcs as well,I now have the upper arms and lever.
again, thanks to all!
jerry
1031D
12-28-2006 20:46:22
 Re: vac-14 clutch stuck in reply to j stice, 12-27-2006 08:04:15
I always have had luck driving it up a hill in 3rd with the clutch all the way down and stomp on the brakes repeatedly, eventually it will pop. I had one that took a 2-16 plow 8" deep to pop.
IBorange in TX
12-27-2006 09:46:02
I would give a good shot of brakeshoe cleaner on the clutch, then if you have a shredder mower, put that on, then tie the clutch pedal down and get out there and mow the pasture. When it gets hot, it will break loose. Then give another shot of BScleaner to the clutch. I also agree, when you park the tractor, use the small wooden block on the clutch pedal. As all ways, be careful when using a mower. HTH
Good Luck..... ..
Jim Yadon
12-27-2006 08:27:51
There are just a few tricks. 1st one is that I would place the tractor in 4th and start the rocking process. Sometimes that will cause the clutch to release. If that does work get your handy strap or chain. Pull with another tractor or a truck leave in 4th. Make sure there is gravel or some loose ground so it won't be so hard on your transmission. When you start pulling make sure you don't go real fast. Sometimes that will work. Last thing on a Vac Case is every fall before you park the tractor be sure and use that little hold block on the side of your clutch this will not allow the clutch to get stuck cause from condensation in the flywheel.
Good luck and you have the final answer and that would be slit the tractor and if your that far into you might as well put a new clutch in while you are there. So there is a little more than just splitting the tractor. Cause you only want to split a tractor once.
