hydralic problem
ontario 930
12-26-2006 15:30:42
I have a 930 hydralic problem Both the outlets work so its not a pump problem. But when I want to raise the arms for the three point hitch to work I cant raise my semi mount plough please help
dwag
12-26-2006 17:59:49
 Re: hydralic problem in reply to ontario 930, 12-26-2006 15:30:42
1 Make sure sensing lever is engaged in front notch on platform. 2 lift off center platform\seat an make sure hitch linkage is is working,spring hooked to end of spool. With sensing held ahead, hitch spool should move in and out a couple,3 inches. (in=lower out=raise) 3 Dissamble hitch valve, clean and reseal.
ontario 930
12-30-2006 08:58:05
 Re: hydralic problem in reply to dwag, 12-26-2006 17:59:49
Hey Dwag Thanx for your responce to my tractor hydralic problem. Bud, I diid everything you suggested but clean the hitch valve. Do you think dirt is blocking the valve from opening all the way I changed the hydralic oil and put a new filter on the block. I was told that some kind of valves inside arent lined up enough or coinciding to make it lift I dont know. Tell me more about youre therory!!! hitch valve thing
