Case O Matic , 530CK
Phil (Nj,Az,Sas
12-25-2006 12:34:35
There was another thread RE: direct Drive but its dropped to page 2.
My question is with regard to the Spools in the
COM control valve. ARE both spools identical & exchangeable or are they each unique?
Background:
I at one time had the correct pressure in both
modes but since last year,or near the last time I had the Valve apart to clean & blow back, the Direct drive has had very low pressure. The clutch does engage. I have played with the Direct spool and did increase the pressure some but fluid is still been dumped.
Jim from Calif
12-25-2006 13:15:39
 Re: Case O Matic , 530CK in reply to Phil (Nj,Az,Sask), 12-25-2006 12:34:35
Phil: I too have a Case 530 w/caseomatic. My question is: When you engage direct drive, does the 530's direct drive clutch engage with a jolt, or does it just stealthily slip into direct drive? Thank you, Jim
Phil (NJ,AZ,SasK)
12-25-2006 21:41:11
 Re: Case O Matic , 530CK in reply to Jim from Calif, 12-25-2006 13:15:39
JIM,from Cal
No Jolt. It does engage but I don't think you could do any pulling work with mine. I only use it when moving unloaded. When I originally got mine the Filter was plugged (I thought the paper filter was ceramic) and Direct Drive would bog down on an up hill. I have replaced seals & parts (new Gauge) in COM valve assy & Regulator. I have the books, with instructions, and I think the valves may be swapped.The COM Clutch had crap/paper that got by the filter and I have needed to clean the valve assy several times
I am in AZ and 530CK is in Sask, up to its ears in the snow.The low pressure (direct) bugs me
BTW: the Direct Drive clutch didn't operate any
better when its presure was normal.
Phil,
J Heitkemper
12-25-2006 20:18:46
Merry Christmas to all from page 2,will try for the 4 time to post the message.My 800 should have a decided jerk when engaging in direct drive.your 530 is problably is the same,my tranny works fine in '95 when we parked this tractor,pressure gage no longer works,tranny is clean inside and filter has captured silicone residue from a previous sloppy job.my hope is the silicone has lodged in a critical area in the valve block. Using John Deere 303 fluid. Not ready to do a tractor split just yet. I certainly feel something is plugged somewhere. Thanks for all of your help! Jim on Page two. No Direct drive.
Phil (NJ,AZ,SasK)
12-25-2006 21:56:59
 Re: Case O Matic , 530CK in reply to J Heitkemper, 12-25-2006 20:18:46
Jim, see above post. I had paper (filter) clogging my COM valve (Spools). The FEL makes mine a little difficult but taking it off is easy. The last time I had Clogging I also removed the filter and used air pressure to blow back the Lines to the PUMP.
My 530CK hoe was used in the OIL Patch, used hard and put away wet. I have turned a lot of wrenches on the puppy.
Good Luck,
Old Magnet
12-25-2006 12:56:36
My parts book shows same number for both spools.
Phil (NJ,AZ,SasK)
12-25-2006 22:04:21
 Re: Case O Matic , 530CK in reply to Old Magnet, 12-25-2006 12:56:36
Thanks! I know I may have swapped them and I can now scratch that from my possible fault list.
Phil
