open station
gortex
12-25-2006 07:30:51
When you see an ad for a tractor for sale
sometimes the ad will say "open station" , A term used for the hydraulic system.
What does this mean and how does it work
Thanks
Gortex
new to site
12-27-2006 05:55:29
 Re: open station in reply to gortex, 12-25-2006 07:30:51
that is term that john deere coined. [no cab]
Gene Dotson
12-25-2006 11:24:28
I suppose the term you are referring to in relation to hydraulics would be "open center" as apposed to "closed center" hydraulics. Open center system is constantly pumping oil through an open circuit until a load is required and then the valve closes and redirects the pressurized oil to the required load. After the required operation, the valve is returned to the neutral position, allowing the oil to again freely circulate. When the valve is released, the oil is allowed to re-enter the stream to the reservoir and the load released.
Closed center hydraulics have a constant pressure at the valve at all times with the pressure being maintained by a variable displacement pump.
Either system has advantages with the closed center being a little faster to react and the open center is easier to feather a light load and costs less to build... Gene
earthmasterk
12-25-2006 08:18:28
A tractor with an open station means a tractor without a cab and/or without a roll bar.
