VAC engine swap
Scott in Mich
12-23-2006 07:30:07
Is there an engine that will bolt into a '51 VAC that has more cubic inches? What would it be found in?
Scott in Mich
12-23-2006 14:20:51
 Re: VAC engine swap in reply to Scott in Mich, 12-23-2006 07:30:07
What is the major difference in a VAC engine and a 159? Does it have a bigger stroke? Could 159 parts be swapped into a 124 block? Is the 188 gas motor longer than the VAC?
530puller
12-23-2006 17:22:44
 Re: VAC engine swap in reply to Scott in Mich, 12-23-2006 14:20:51
I'm not sure exactly what the difference is in these two motors but I think the bore and stroke are bigger on the 159. I'm not sure which parts could be swapped over I think that the 188 is the same block as the 201, so it would be 2 inches longer too.
530puller
12-23-2006 14:06:51
 Re: VAC engine swap in reply to Scott in Mich, 12-23-2006 07:58:12
I believe the 159 engine is the same block as a VAC so it should be the same length. The 159 is hard to come by though, it would be easier to find a 201 out of a combine
530puller
12-23-2006 07:44:31
I put a 201 ci gas engine from a Case 660 combine in my Case 530. It bolted right in after switching flywheels but the block was about 2 inches longer that the standard block. I believe this same motor will work in a VAC.
BarryfromIA
12-23-2006 17:13:31
 Re: VAC engine swap in reply to 530puller, 12-23-2006 07:44:31
The clutch flanges on the back of the 188/207 engines are way different than a VAC block, but it has been done by a tractor puller.
mike's600
12-24-2006 05:39:52
 Re: VAC engine swap in reply to BarryfromIA, 12-23-2006 17:13:31
The early 148 will bolt in with no problems. The 159,188,201, will not with out mods. to the torque tube and sheet metal.
