CaseO matic no direct drive
J heitkemper
12-22-2006 20:24:04
Got back to the 800 for a bit ,,It seems that the real problem is that direct drive will not engage ,,from other posts it seems that my problem is in the valve assembly block on the clutch side ,,Any advice and experienced wisdom would be most appreciated ,,Thanx Jim
Grumpy
12-23-2006 05:51:54
 Re: CaseO matic no direct drive in reply to J heitkemper, 12-22-2006 20:24:04
Your direct drive clutch plate is probably wore out. If your clutch pressure is good then you will need to split the tractor to repair. Stan
gary case
12-24-2006 06:47:59
 Re: CaseO matic no direct drive in reply to Grumpy , 12-23-2006 05:51:54
Grumpy what about if they're isn't any pressure to push clutch down. this is a different tractor 411b. everything else is new,filters,fluids,etc. shifts good, if you rev, then idle down and shift for the first time. COM works real good. will set you back in the seat when shifted down. the clutch is like there's nothing there,yet will disengage to shift to another gear or stopping. thanx gary
Grumpy
12-25-2006 06:05:52
 Re: CaseO matic no direct drive in reply to gary case, 12-24-2006 06:47:59
The clutch pedal just moves a spool in COM valve. The only resistance is the pedal return spring. Push the pedal down with the engine at an idle. Count to 5 more if cold less if hot. Put 4 speed in gear let clutch pedal up. Don't try to slip clutch you can't. Speed motor up til you start moving just like you do with a auto trans in your car. When your moving easily shift to direct drive. Sounds like yours is working OK Stan
jheitkemper
12-23-2006 10:46:02
With all due respect to you grumpy ..Could Be, but I hope not ,tranny Used to work real good around here until about 1995.. then .engine wore out , and fuel pump was leaking fuel into oil ,so Tractor sat in back of shop for nearly 10 years ,Recently Rebuilt motor ,and fuel pump , starts and runs like a champ,,Tranny is not right,though , I am hoping there is a valve sticking someplace .Thanx for prognosis And I wish you a Merry Christmas ,Jim
Roger (Mi)
12-24-2006 05:37:00
 Re: Case O matic pressure? in reply to jheitkemper , 12-23-2006 10:46:02
Grumpy may be right. Watch the pressure gauge. When you take your foot off of the COM foot pedal, the pressure gauge on the dash should go to the normal range. (The multipule clutch disks are engaged.) When you move the direct drive lever to the direct position, the pressure should drop momentarily then return to the normal range. (The direct drive disk is engaged.) If the pressure drops and fails to return to normal, something could be wrong internally. Before splitting, check the obvious: oil level, case-o-matic filter, relief valve on the control valve body.
Roger (Mi)
12-24-2006 06:19:58
 Re: Case O matic pressures good? in reply to Roger (Mi), 12-24-2006 05:37:00
If the pressures for the multiple clutch disks and direct drive disk are both good and there's no lockup in direct drive, Grumpy is totally right!
