case vi
Ron Wigen
12-22-2006 19:50:32
I have a 1941 case vi i have been working on for
a while. Is there anyone out there that has one
or knows a bit about them. i am trying to find a generator for mine that fits thanks Ron Wigen
Gene Dotson
12-23-2006 05:55:59
 Re: case vi in reply to Ron Wigen, 12-22-2006 19:50:32
Ron;
I checked my generator on the tractor with the original generator. The spec number is Auto-Lite GBM 4809B 5.
Also listed in my manual is GBM 4804A 5, GAS 4160A and GAS 4162A.
The cutout relay is CB 4014
There were 25 tractors built with Delco-Remy generators. Part number 1101366.
These tractors use a positive ground system.
The Continental F series engines were use a lot for commercial machines. They were used for generators, welders, water pumps and many other uses, so this may be a source for what you need... Gene
Gene Dotson
12-22-2006 20:47:36
Ron;
I have a V and a VC that both have generators from Ford trucks from the early 50's. They are 6 volt and the installation looks neat. Uses a seperate regulator which has been mounted in the toolbox.
I can check the stock generator tomorrow to give you the number for that... Gene
