type of oil to use in 211B
scman
12-22-2006 19:08:13
I have a 211-B triple range and was wondering what type of oil to use in the triple range,transmission and the rear end. This tractor also has a hand pto clutch if for some reason that would make a difference. Thanks for the help
iluvcase
12-29-2006 21:14:40
 Re: type of oil to use in 211B in reply to scman, 12-22-2006 19:08:13
Here's the scoop from an original Case owner's manual. The transmission and differential holds 5 gal. of SAE 90 E.P. oil. It takes 12 qts. of 10W-30 to fill the triple range unit. If you want to use an alternate oil in the triple range unit you can substitute automatic transmission fluid type "A". We used to use the same fliud in the hyd. system and triple range....we got it at the Case dealer. Years ago it was called TCH....Torque converter and hydraulic fluid...today it's called something else.
JGarner
12-24-2006 06:46:11
With all due respect to Gene, if the 211b is like my 630 the transmission/differential (shares gear lube via communication ports)use 90W gear lube and the triple range that shares fluid with the remote hydraulics and 3pt, if so equipped, need uhtf fluid.
90W is much to viscous for the hydraulics!!
Eldo case
12-23-2006 06:37:21
Use uhtf in the triple range hydraulic section. Use 80w 90 in the rear end. Not in both!!!
Gene Dotson
12-22-2006 20:50:49
Use 80W-90 gear oil. The clutch is not affected by the oil... Gene
