VAC clutch question
Casekernel
12-22-2006 14:07:43
Noticed that sometimes, with emphasis on "sometimes" when I try to shift from 2nd to reverse and back, I have to grind gears to get it engaged. Other times it shifts fine. I use it for plowing snow, so there's a lot of shifting between those two gears. The clutch, otherwise seems to work fine. Any ideas???
mj
12-24-2006 06:56:36
 Re: VAC clutch question in reply to Casekernel, 12-22-2006 14:07:43
It's a non-synchro transmission so sometimes the gears are lined up when you go to shift and sometimes not.....Roger?
Gary Cash
12-22-2006 14:22:33
My VAC does the same thing. My clutch works fine with no slippage under heavy load.
