2090 case
ghoel
12-22-2006 13:11:00
need a little more power wondering how i can get turning the fuel screw without turboeing any input is greatly appreciated.
4435
12-25-2006 12:12:54
 Don't twist her tail much in reply to ghoel, 12-22-2006 13:11:00
The 2090 is a cheapened version of the 2290 and turning the smoke screw will cost you. The brakes are 2 disc versus 3 and a little two much power will cause you some expense there. Don't ask how I know all this stuff. Make sure you please plenty of room for wheel slip. Tom
Grumpy
12-23-2006 05:47:20
 Re: 2090 case in reply to ghoel, 12-22-2006 13:11:00
There is a small plate on the back of the pump maybe 2 in. by 2 in. Takes a 10 mm wrench on the screws. Remove plate. At the bottom of the opening will be a small screw with a locknu. Loosen locknut with 10 mm wrench and turn screw in one quarter turn. Butten her up and try her under a load. You should notice a differance. If not try one more quarter turn. I would rather not go more than that. You might need to turn RPMs up 50 also Stan
