Weight Distribution of a 'D'
Mathias NY
12-18-2006 13:05:38
Does anyone know how much of the weight of a 'D' is on the front wheels?
The tractor is in the 5000-6000 lb range, can I expect 20% of this to be on the front tires?
Thanks for the help.
Don Rudolph
12-18-2006 20:27:14
 Re: Weight Distribution of a 'D' in reply to Mathias NY, 12-18-2006 13:05:38
I would bet good money that a D has almost 50% of its weight on the front tires unless the rear tires are loaded with solution. The cast iron grille and radiator sit out in front of the front axle and balance out the hydraulic/PTO housing. Don
Tom Railsback
12-20-2006 10:27:18
 Re: Weight Distribution of a 'D' in reply to Don Rudolph, 12-18-2006 20:27:14
I would agree with you Don. I haven't hauled D's too much, but I occasionally haul my C and it makes no difference on how the trailer pulls whether I load it forwards or backwards as long as whichever end is closest to the back of the trailer is centered between the trailer axles.
Mathias NY
12-20-2006 16:37:53
 Re: Weight Distribution of a 'D' in reply to Tom Railsback, 12-20-2006 10:27:18
Thanks for the replies.
Mine had loaded tires, so I can't tell what a normal one would do.
