Small Case Tractor.
Chris in Ohio
12-17-2006 10:17:54
Hello,
I am wondering, did case ever make a small tractor kinda like the Farmall Super A? Around 20 horsepower? I am thinking of finding a case, and using it to mow the lawn and garden and such with.
Thanks,
Chris
'53 VAI Guy
12-18-2006 15:21:00
 Re: Small Case Tractor. in reply to Chris in Ohio, 12-17-2006 10:17:54
Actually, a VAI is a good all around 20hp tractor with wide front wheels(if you can find one). The VAC is OK, but close crop tires aren't the best for all around utility purposes. You will find some bare bones VAIs with nothing but a trailer hitch, and others loaded with hydraulics, PTO, and 3 point. (This is my biased opinion) Good luck.
C. Amick
12-19-2006 09:22:24
 Re: Small Case Tractor. in reply to '53 VAI Guy, 12-18-2006 15:21:00
Here's one in the Photo Ads that I think is a VAI, see link below?
JeffL-TN
12-18-2006 13:06:49
See my classified ad on this site. My dad's VAC with 2 row cultivator is on there. Price is negotiable. Also have 2 bottom plow, spring tooth drag and spike tooth drag that could be thrown in for the right price. Located in S.E. MI.
C. Amick
12-18-2006 09:19:02
Some of the VA Series tractors would probably work for your use. The VAS had the offset engine like the Super A. The VAC is set up to cultivate 2-rows, like the Farmall C.
TimBinWV
12-17-2006 14:13:11
Hey,Chris, Try ebay #140063680634. It's exactly what you're looking for....maybe....
Brian in Ohio
12-17-2006 10:36:45
I would think your best bet would be a VAC. Not exceptionally big, parts are easy to come by, and there's a bunch out there. They look good shined up, if you want to show it too.
Chris in Ohio
12-19-2006 14:03:27
 Re: Small Case Tractor. in reply to Brian in Ohio, 12-17-2006 10:36:45
Thanks guys. I will check out the ads and ebay. Thanks alot,
Chris
