Case fuel tank
Andy In Arkansa
12-16-2006 16:49:21
Hey guys,
My bud came back from Nebraska with a 200 gallon fuel tank that has the case eagle on the fill cap and hase CASE stenciled on the side. Anybody know anything about these things? Was there many of these?
Thanks, Andy
Glenn/mn
12-17-2006 12:42:49
 Re: Case fuel tank in reply to Andy In Arkansas, 12-16-2006 16:49:21
Sounds to me if it is not riveted, it is a fuel tank made during the late 20's into the 30's I have only seen on other if possible you could post the casting number of the lid or any other parts that have a number to confirm its identity, I have a catalog picture that I could post
Glenn/Mn
12-17-2006 12:59:24
 Re: Case fuel tank in reply to Glenn/mn, 12-17-2006 12:42:49
I put it in Implement Photos, I think we are talking about the top one
Andy from Arkansas
12-17-2006 17:56:13
 Re: Case fuel tank in reply to Glenn/Mn, 12-17-2006 12:59:24
Hey Glen, You hit the jack pot. Looks like what he has. I'll post the cast # of the lid and the stenciled # on the tank itself. I wonder how rare this is? It looks like it is stick welded not rivited.
Andy
Glenn/Mn
12-17-2006 19:05:37
 Re: Case fuel tank in reply to Andy from Arkansas, 12-17-2006 17:56:13
I have only seen one other, it is in Yankton SD, how rare it is I do not know, if it has the orginal running gear then I would say it would be truly one on a kind, I would encourage you to send a photo and a short article into one or both of the Case magazines, this may start others to looking for simular tanks and may put you into contact with people that own one like yours as well, Great Find!!!
Andy from Arkansas
12-17-2006 19:34:05
 Re: Case fuel tank in reply to Glenn/Mn, 12-17-2006 19:05:37
Glen, This one is less the running gear. On "skids". Will get the #'s tomorrow and try to post them.
Andy
Andy from Arkansas
12-17-2006 11:32:23
Sorry guys, I,m to tech. deficiant to do a picture. I'll see if I can get one of the grandkids or someone to do that. It has been used for diesel fuel In later years. It's not off a tractor but rather is a fuel holding tank of about 200 gallons. The ends are rounded out like a propain tank but not as pronounced. The Screw on lid is a solid molded, flat surfaced,1 1/2 to 2 inches diamater plug with Old Abe cast in the face of it. It does have ears on the cap. It is on about 8" blocks that have a slot cut our in it for the bands to go through. I'm thinking that it may be a tender tank for a steamer that someone just started using for a fuel tank. It's interesting. I'll post more as I get it. Thanks
Andy
Tom Railsback
12-17-2006 10:00:18
Some of the old catalogs show fuel tender tanks. Does it have a cap with ears on it?
Curious
12-17-2006 01:03:14
Andy, does it look like newer production? Could it be off of one of the big 4 Wheel units? The thing is I doubt if they used an eagle on the cap. Could it be a water tank from a steam engine?
Brian in Ohio
12-17-2006 04:29:10
 Re: Case fuel tank in reply to Curious, 12-17-2006 01:03:14
My first thought is it's a water wagon, and not a fuel tank. And if it has a cap on it similar to the caps used on the fuel tank of a Crossmotor, they have Old Abe on them.
Pictures would be most helpful...
