ALLIS B RUNNING ON ONE STILL
gary case
12-14-2006 10:57:49
well i sprayed the caps inside and out with starting fluid and couldn't see any cracks. retimed it again just for the heck of it. wires good.fired her up, an the same. i pulled the wires one at a time while it was running. the only one sparking was#4,super spark so i'll just wait for the new points,cond.,rotor. i'd hate to paint it JOHN DEERE GREEN JUST cause it sounds like one. not that there's anything wrong with that.
L.Lamp
12-15-2006 13:36:01
 Re: ALLIS B RUNNING ON ONE STILL in reply to gary case, 12-14-2006 10:57:49
I'm a Case man but I have a C Allis too. The firing order on all Allis Chalmers engines is different than other 4 cylinder engines. The order is 1-2-4-3. If it fires on 4 change the other wires in clockwise order looking at it from the distributor or mag cap to 3-1-2. That should make it run fine unless you have other problems. Good luck!!
gary case
12-16-2006 07:23:04
 Re: ALLIS B RUNNING ON ONE STILL in reply to L.Lamp, 12-15-2006 13:36:01
thanx L.Lamp, tried that many times. i must have a bad coil. i've got to wait and get my points condencer,and rotor replaced before i go any further. if they would just GET here. Gary
JGarner
12-19-2006 05:45:39
 Re: ALLIS B RUNNING ON ONE STILL in reply to gary case, 12-16-2006 07:23:04
Gary, FYI NAPA auto parts carries a LOT of parts including ignition parts for old tractors. Instead of ordering and waiting you might try them. They can usually get parts overnight if they don't have them in the store the day I go in.
gary case
12-19-2006 06:06:40
 Re: ALLIS B RUNNING ON ONE STILL in reply to JGarner, 12-19-2006 05:45:39
thanx JGARNER, I FOUND IT ON EBAY and thought it was a good deal,so i bought it. i agree napa is great in getting your parts. i got my parts yesterday. i'll be putting them in maybe today. feeling pretty much under the weather right now. something we get to look forward to when winter comes. gary
