help to identify case tractor
D.C. Gregory
12-14-2006 08:21:47
hey,
my friend picked up an old case tractor he needs help to try an identify model+year,it says case triple range on side can't find any other tags or markings,its got belt pulley with hand clutch,wide front, manual trans,3point,4cyl gas,sand color hood with dual headlights with eagle symbol between them,p/s with generator on right seated on tractor,couldn't match to photos shown on this site any help to identify or how to would be greatly appreciated, he plans on a rebuild an restore project, thanks again.
TimBinWV
12-14-2006 09:24:47
 Re: help to identify case tractor in reply to D.C. Gregory, 12-14-2006 08:21:47
Could be a 311b also. There's a foot clutch,too?Should be...
jim yadon
12-14-2006 08:50:20
Looks like your friend just got a case 430. If you go to tractor photos and do a search for case 430 you should be able to see if there is a picture that looks like his tractor. I the ID tag should be directly under the steering wheel on the downward slope or right at the bend of the dash. If not there look for two small holes about 3" apart and that would tell you where the serial tag would have been. The tractor should have 12 forward speeds and 3 in reverse. That will give your your triple range. You can use the hand clutch like a live pto. Have fun and good luck finding the tractor
Gene Dotson
12-14-2006 14:39:13
 Re: help to identify case tractor in reply to jim yadon, 12-14-2006 08:50:20
Jim;
Have you heard anything about thr video from LaGrange? November has passed and I haven't received my copy of it yet... Gene
JGarner
12-14-2006 13:10:00
Could be a 530 or 630 too. Describe the rear hub/wheel and give us the tire size. If it has spinout rims how many slide bars does it have?
