580 CK Parts
Greasey Hand
12-12-2006 12:22:42
Need to know where to find a G 11342 Pully (fan drive) for a gas motor, have found 4 of them & The seal area was bad & on some they had been welded up & were very bad shape.
Also need the flywheel pilot A 40878 on the torque converter, Bolts on to it.
I have tryed to find these parts but it seems I cant find a good one.
Maybe some of you have these parts or now of a yard that might. Hoe has been apart for severial years now.
John Saeli
12-12-2006 15:25:43
 Re: 580 CK Parts in reply to Greasey Hand, 12-12-2006 12:22:42
Your Case dealer should be able to get you a repair sleeve kit & seal for that crank pulley. Very common. They should also be able to get you the converter part. Good luck.
Greasey Hand
12-12-2006 19:35:33
 Re: 580 CK Parts in reply to John Saeli, 12-12-2006 15:25:43
The pulley, The key way is shot, I could have a new keyway cut in there but than the timing mark would be off. Thought it would be better to get a used one.
