fan belt replacement
Sid in VA
12-11-2006 18:01:48
I recently got a Case 530 with 31 backhoe and found that the fan belt was busted. There are three pulleys to place the belt on, but I can't figure out how to get the belt on the bottom one which has a shaft going out the front to the hydraulic pump. Can anyone tell me how to seperate that front lower shaft to put the new belt on?
Old Magnet
12-12-2006 16:12:19
 Re: fan belt replacement in reply to Sid in VA, 12-11-2006 18:01:48
Well, your pushing my memory. I went out and took a look and although it is tight I would start out by unbolting the coupling flange and pushing it forward. There is ample room for the flange in the cast framework and I see plenty of splined shaft but the cutout in the radiator mounting flange looks a little iffy. Having the radiator out would sure give you more working room. Sorry I can't be more specific but I just don't recall it being a big deal.
630crazy
12-12-2006 08:57:01
My dad used a power twist belt on our 580 for 10 or 15 years before he sold it, probably still has it on today. Their are several different widths. Sure beats tearing the whole frontend apart.
http://www.grizzly.com/products/g8127
Old Magnet
12-11-2006 19:58:18
It's been awhile but I believe it goes like this. Unbolt the flex coupling (4-bolts) from the crankshaft pulley and slide the flange back on the splined shaft. This should give you enough room to pass the belt through. The part I can't remember for sure is there's a snap ring on the splined shaft that holds the hydraulic pump coupling in position and it may require release from it's groove to further telescope the splined shaft.
Sid in VA
12-12-2006 07:01:41
 Re: fan belt replacement in reply to Old Magnet, 12-11-2006 19:58:18
I assume you are referring to the coupling between the radiator and the engine block. Do you need to pull the radiator to loosen the coupling?
