Case 530 Hydraulic Question
Josh Gun
12-11-2006 14:12:07
I have a Case 530 loader/backhoe that I have been repairing. I have removed the backhoe and now the pump is building pressure and not allowing the tractor to start. My question is do I need to connect the pressure and return lines on the back of the tractor or is there an unloader valve on the loader that needs to be adjusted or installed? The hydraulics work fine when the backhoe is installed making me believe there is an unloader valve on the valve manifold set on the backhoe. Any help would be greatly appreciated.
awh
12-13-2006 13:41:16
 Re: Case 530 Hydraulic Question in reply to Josh Gun, 12-11-2006 14:12:07
Hook the pressure and return line together at the back and it will work properly.
Old Magnet
12-11-2006 15:54:03
On my unit when the backhoe is removed you take the pressure line with the quick disconnect coupler and connect it to the return line at the loader valve.
