I was doing some repairs/cleanup/degreasing on the Case 830 yesterday and discovered some suprises.I remember JGarner mentioning that it looked like someone had replaced the Eagle hitch arms on our tractor..I think I now know why. After scraping off all the caked on stuff around the lower portion of the hitch, I found some nasty situations! One side (the right side, facing forward) of what is left of the hitch has been completely rebuilt of plate steel. However, it does appear this was done by someone who knew what they were doing, as the welds are very well done, and the fit is excellent. There is a lot of angle iron bracing under there that I don't think is original, with arms going forward under the tractor to about under where the seat is located. Huge bolts are in position on either side of the tractor there. At the back, on the right side, there is provision for two bolt attatchments, however, it appears one bolt is either stripped out, or too short (I hope! I will know when I get back from the hardware) to grab the threads of the cast original hydraulic housing. That BAD part, is the left side of the hitch...it appears the "bosses" cast into the left side of the hydraulic housing broke away a long time ago. Only one bolt, of the original three, that go through the lower part of the hydraulic cylinder and into the casting, appears to be holding things together. There is a steel plate there, on the outside of the "ears" of the hydraulic cylinder, that was bent away from what is left of the bolt holes, and two of the bolts were just sitting there, not really threaded into anything, but supporting part of the weight of the hitch and implement. I was able hammer the plate back straight, and one bolt caught, and threaded into, what if left of the threads in the body of the hydraulic housing...I don't know how many threads are left in there, but I know it can't possibly be as strong as original. I am hoping, as on the other side, that a longer bolt in the one remaining position with allow it to thread into what is left in the body of the hydraulic housing as well. Here is an area where a picture really IS worth a thousand words, so I will try to get one posted, ASAP, for all of your's purusal and comment...it's really a Rube Goldberg affair, but necessity is the mother of invention, and apparently it has served it's purpose for many years. My next comment and question is: Thankfully, those bolt holes are cast into a piece that is removable and replacable, rather than the entire cast "frame" of the tractor. However, how difficult is it going to be to find that part? The whole housing of the PTO and hydraulics? I am going to have to make use of things as they are for now, but I probably better start looking for spare parts now, with the future in mind. It could last another lifetime, or the whole works just might bust off next week..
