water in hydraulics
kboi
12-11-2006 06:38:12
So I have this 830 case comfort king and it has some moisture in the hydraulics/trans case. I would like to change it before its get real cold here in iowa, as it is, in the mornings it is really slow. My question is how would I go about getting all of the moisture out? If i just drain the case with the 2 plugs on the bottom and change filter, is there still moisture in the lines to the bucket? I was told once to run some diesel fuel through it while it is empty, what exactly will this do? Will I need to take all the lines off and drain them? then bleed them? or is bleeding not required?
SHeiserman
12-11-2006 09:03:19
 Re: water in hydraulics in reply to kboi, 12-11-2006 06:38:12
There are actually 3 drain plugs. The third one that is located on the lowest point of the system is fairly hard to find. It is up between where the drawbar and three point arms bolt to the tractor. If you've got a c-o-m, that has its own separate drain plug.
I've never flushed the housing out, just drained and refilled. Won't have to worry about bleeding it.
Camboted
12-11-2006 07:12:19
Personally, I'd just drain it and refill. I don't think the diesel flush will hurt anything, but, if you are worried about water in the lines, and if you have a lot of water in the reservoir, you should pull out the bottom plug and drain off some of the fluid after the tractor has been sitting for a day or so. Let it run until you don't see any water. Then I'd pour in a can or two of "Heat" (Used for preventing gas line freeze) it will absorb the moisture in the oil. Run the tractor until the oil is warm, then drain it and refill. That should do it.
