Case 685 Loosing Prime over night
WV Kevin
12-10-2006 13:32:12
I have a Case 685 4x4 diesel and it is loosing prime over night and have ran out of things to look for.
I have replaced the primer pump,All fuel line including injector return lines.
Im thinking maybe the injection pump is bleeding off into the fuel tank.
J heitkemper
12-10-2006 19:10:26
 Re: Case 685 Loosing Prime over night in reply to WV Kevin, 12-10-2006 13:32:12
Hi Kevin, Just trying to help with my own experiences ,My 430,, 1967 was playing a similar joke this summer ...To check the problem , Rather than pull the kill lever shut-off,at the end of day ,I stalled it in high gear and parked it in 1st gear , ,and left it set,,, a couple days ,later , It Started right up like normal ,,Turns out something was sticking inside the pump on the fuel cutoff ,, My Perkins ,Combine motor taught me the ropes with this trick ,,Perhaps your tractor has electric shut-off and all the other modern complicated garbage installed to make your life more TROUBLE -FREE,and this info is useless ,, Good Luck, Jim
TimBinWV
12-10-2006 15:32:24
Hey,Kevin,be sure to keep a close eye on your oil level. If it's leaking into the oil,it will thin the oil and wash out your crank bearings..... .
