Case front wheel types/options
DX29
12-09-2006 13:25:02
What type of wheel options were there for the case VAS. Ive seen the rims that bolt on to the hubs and I've read a post wher somone said they also came with cast iron wheels. What was standard and what was optional?
amo
12-09-2006 14:40:20
 Re: Case front wheel types/options in reply to DX29, 12-09-2006 13:25:02
I THINK THE REGULAR RIMS WERE STANDARD AND WHEEL WEIGHTS COULD BE ADDED ACCORDING TO MY MANUAL. I HAVE A 1952 THAT WE ARE 75 PER CENT FINISHED RESTORING AND IT HAS THE HEAVY HEAVY SOLID CAST IRON RIMS 15 INCH ON THE FRONT. PROBABLY 125---150 POUNDS EACH. THE REAR ARE THE REGULAR RIMS AND WHEELS. TRY DOING A SEARCH UNDER TRACTOR PHOTOS AND YOU MIGHT GET SOME MORE INFO.
DX29
12-09-2006 14:56:46
 Re: Case front wheel types/options in reply to amo, 12-09-2006 14:40:20
Wow - 125-150lbs each? That seems pretty heavy for a 15 inch wheel. I have some cast iron front wheels from a JD model M and they are not near that heavy. Maybe 50 lbs each. I'd like to see a picture of your wheels if you could post it. My vas has some steel pressed front wheels - looks like wheels off a JD tractor - not sure though
