case 1840 skid steer electrical problem
JRDARNO
12-08-2006 18:05:16
I just bought a 99 Case 1840 skid steer at an auction. It has 720 hours and runs and operates great. One issue is that when I turn on the flood lights, after about 30 seconds the engine sputters and dies. If I catch it quick enough and turn the lights off the engine will catch and not die. I can't find any shorts in the wiring. Any ideas?
just Case
12-08-2006 18:30:55
 Re: case 1840 skid steer electrical problem in reply to JRDARNO, 12-08-2006 18:05:16
There are three relays in the main wiring harness located in the engine compartment. It could be one of these relays that is bad. Case part number D128310 Relay.
jrdarno
12-09-2006 09:55:09
 Re: case 1840 skid steer electrical problem in reply to just Case, 12-08-2006 18:30:55
Thanks for the relay idea. I"ll see if I can swap the relays around to try to isolate a bad one.
Do you know what voltage level is required to keep the engine running? I"m wondering if the alternator is weak and can"t keep up when the electrical load is high. I was going to try to measure the voltage when it starts sputtering.
