Case SC 1948
Jim Wooley
12-08-2006 16:39:13
Just got my new adventure home. The tractor is complete with very good tin and the cultivators and planters.
Once we got it out of the weeds i could see that the pan was loose on one side. The starter was in one of the planter hoppers. The gentlemen that i bought it from said he did not have a radiator cap on it when he ran it so i suspect that there is a water leak somewhere.
I would like some suggestions on where to start. Do i put the starter in and try and turn it over, or should i just plan on a complete tear down and rebuild?
thanks...Jim
911oldschool
12-10-2006 09:28:36
 Re: Case SC 1948 in reply to Jim Wooley, 12-08-2006 16:39:13
Just Purchased an 1950(?) SC myself, brought it home friday. I am dieing to get started, but dont want to put the cart before the horse. I know mine well have to have a total rebuild... WHERE DO YA START?
C. Amick
12-09-2006 13:29:58
I would start by pouring oil in the cylinders and let it soak for several weeks. I would remove the valve cover and put some oil up there as well. I would start by trying the get all the valves freed up. If you try turning over an engine with stuck valves, you will bend the push rods. There are some good articles in the "Articles" archives on this web site regarding freeing up stuck engines. One guy used a mixture of one part Marvel Mystery Oil, one part automatic trasnmission fluid and one part kerosene; and be patient.
