Where to put LA headlights
SDLars
12-07-2006 19:03:11
Does anyone know if there was a certain serial number or date when LA headlights were moved from the fenders to the radiator? When they moved to the radiator, were the same flat lensed lights used or were the DC type lights used? Thanks for your help!
SDLars
12-08-2006 09:03:30
 Re: Where to put LA headlights in reply to SDLars, 12-07-2006 19:03:11
Thanks for all the help! I wanted to hear what others had to say. My 48 has them on the fenders while the LA on the cover of my parts book (late version) shows them on the radiator. The parts page shows both fender and radiator mountings and the brackets that mount the radiator positioned lights are the same brackets as used on DC's. I just picked up a '51 with no headlights and was wondering where they should go.
DurangoCase
12-08-2006 10:06:34
 Re: Where to put LA headlights in reply to SDLars, 12-08-2006 09:03:30
I think radiator mountings are pre drilled if the lights are on the front.
jdacih
12-08-2006 07:56:46
my 1948 has 7 inch flat lense lights mounted on the front of the fenders, got a 42 and had a 43 in the same spots.
Engineer20
12-08-2006 07:08:03
My 1950 has 7" flat lights mounted on the fenders.
Bobl1958
12-08-2006 07:02:57
My '52 has lights mounted on the radiator. They are however 7" flatlens which would not be correct so I ordered new ones from Don L. The mounts are correct for the radiator, and the old wiring went up there, so I would guess it was original. Bob
Tom Railsback
12-07-2006 21:57:16
The position was changed from in front of the fenders to the sides of the radiator at No. 5208165 if I read the parts book correctly. However, the LA did not ever use the DC style lamps.
Camboted
12-08-2006 06:23:12
 Re: Where to put LA headlights in reply to Tom Railsback, 12-07-2006 21:57:16
Tom's right about the placement of the LA lights, but in 1952, the very late LA's, did use the same sealed beam headlights as ste SC & DC, part number 09668AB, and combination bulb rear light, part number 08810AB, I believe they were mounted at the side of the radiator.
Tom Railsback
12-08-2006 12:19:40
 Re: Where to put LA headlights in reply to Camboted, 12-08-2006 06:23:12
I didn't read all of my parts book like I should have. Shame on me. I'll have to look at our old LA when I go to Kansas for Christmas and see which type of lights it has; my guess is the early ones as it's a 1951. Maybe I can talk the owner into selling it back to me. Off topic. I just looked at my thermometer and it's 60 degrees here in Great Falls MT at 1:00 P.M. With our infamous wind, it doesn't feel m ore than 45.
Joe C
12-08-2006 16:35:57
 Re: Where to put LA headlights in reply to Tom Railsback, 12-08-2006 12:19:40
60? 45? It was 22 today for the high here, and 3, yes 3 last night, WITHOUT adding (subtracting)for the windchill. 2cents
robertq
12-08-2006 06:28:35
my 52 has fender mounted dc style lamps
Camboted
12-08-2006 06:37:02
 Re: Where to put LA headlights in reply to robertq, 12-08-2006 06:28:35
Could very well be original. My 52 didn't have lights on it when I got it, so I was guessing. The parts book dosn't show the location. Thanks for the information.
