630crazy- Loader on 830?
JGarner
12-07-2006 15:46:22
You guys ever have a loader on one of your big tractors? If so di dthe hydraulic pump mount to the front where the mounting holes and what looks like a cover internal spline is?
Cary below is tryng to figure out if a loader he is looking at will fit on his 830 and how to hook up the hydraulics. Can you use the on board hydraulics plumbed into the loader system directly? At I was first thinking you could, now I am not sure, it been a while since I was around these old gals. I've been a city boy for about 30+ years now, but looking forward to getting back to my roots.
630crazy
12-09-2006 15:23:53
 Re: 630crazy- Loader on 830? in reply to JGarner, 12-07-2006 15:46:22
If you wanted to totally isolate from the tractor hydraulics you could use a pto driven pump and reservoir. It would make it a little difficult to hook up to a pto driven implement though.
Cary Nickel
12-09-2006 20:32:33
 Re: 630crazy- Loader on 830? in reply to 630crazy, 12-09-2006 15:23:53
The loader does come with a PTO driven pump, and has a reservoir mounted on one upright. Factory original, apparently. "Farmhand" is embossed across the tank.
c hess
12-07-2006 16:19:56
Just use on board hyd on 830. Right an left outlets (eagle hitch) AS LIFTING CONNECTIONS. Disconect 2 bottom from eagle cyd an put quiuck connects on both so you can use eagle hitch later. Connect bucket to top 2 remotes.You can reverse hook up but this way if you use left bottom port (ONE that has large adjustable fitting on it)you can regulate lowering speed of loader by adjusting it. As i said yesterday bottom or inside leaver will not have same pressure but should be no problem because if hoses connected right low pressure side would be used to create down pressure on loader.
