where is the cold oil relief valve on 2590?
stephen kosler
12-07-2006 14:45:29
I have read a few post about a 2590 p/s problem and have heard before about a "cold oil" elief valve. where is that located? In the flow/diverter valve?
thanks,
Stephen Kosler
Flatonia, TX
Tom Stanley
12-20-2006 10:27:25
 Re: where is the cold oil relief valve on 2590? in reply to stephen kosler, 12-07-2006 14:45:29
I think you want the trans lube press valve it is on the PS valveon right side of tractor behine fitting a hose connest to just unscrew the fitting
c hess
12-07-2006 16:02:09
First only had 1070 ps apart many years ago so no expert for sure. But yousay shaft stuck out1/8 in farther than when you took apart.Something is not correct.Just a guess but clutch plates are about 1/8in- to many -.not enough. Not what you want to hear but i would not run at all till you find problem. There are others on forum far more knowegable who will help.
