looking for a case 2590 powershift guru
stephen kosler
12-06-2006 15:07:06
Original problem: intermediate and high powershift ranges would not work, just the low and reverse range. The hydraulics made some weird noises
I recently split the tractor and rebuilt that powershift on my 1981 case 2590. A couple clutch pistons had blown o-rings and the friction disks were worn. I replaced all the piston o-rings and seals and all the worn/bad clutch plates. I used the dealers manual that clearly explained all the steps and it all went together easily and all the steps matched what I did exactly. When going back together with the tractor I noticed that the pto shaft that runs inside of the hollow powershift input shaft did not seem to go back into the pto clutch all the way. I could tell because the brass bushing between the pto shaft and p/s input shaft was sticking out about 1/8� more that when I took it apart. I wasn�t sure what caused this because the shaft just goes through the p/s and into the back pto clutch (I didn�t mess with any of that). Anyway, I put the tractor back together and the starter would not turn the engine would over. I remembered the 1/8� from that pto shaft, so I went to the back of the tractor and loosened the 3 bolts that hold the cover of the pto on and this allowed the engine to turn over easily (something was not right with that pto clutch and shaft, but this fixed it.) I tightened the bolts back up and it turned over easily.
OK, so I started the engine and all the gears and ranges were slipping. I then found a bad torque limiter clutch and I split the tractor again and fixed that. I cranked the tractor back up and it was just barely slipping and only in reverse and in 4th (high gear). I put it in 4th and took off and it was slipping pretty bad so I shifted to 2nd p/s (intermediate) and the tractor jumped real bad and then took off (like it should have done in that gear). It was going great for about 45 seconds and then I heard a noise (kind of like a relief valve popping open or a hyd hose busting, but was very short). The tractor still continued to drive good, no other noises, vibrations, rattles or clanks, and about 30 seconds after the noise the hyd filler cap was blown off and a ton of smoke filled the air. I shut everything off as soon as I could. I was scared and pissed off. I was in the middle of the yard so I had to move the tractor. I cranked it up and drove it into the shop. Reverse, low, intermediate, and high p/s worked. I can�t find anything broke despite the smoke and weird noise.
It was in intermediate p/s range when this happened, even though it seemed to be working just fine in that range. It was the low range that was slipping. I have checked all the pressures with gauges and each clutch is getting about 180 psi at the correct time. Lube oil stays at 60 psi until the clutch is stepped in. I have taken the hyd control valve apart twice now and can not find anything wrong with it (no trash, very clean). The springs in the hyd control valve on a couple clutch spools are a little shorter that the book specifies and are probably a little weak, but all they do is bring the spool back after the hyd press is removed from that circuit.
What could the noise have been, especially if all the pressures are still good?
What clutch pack do you think smoked down?
What is with the pto shaft not going back all the way me having to loosen the back pto plate? (1/8� forward too much)
180 psi to the clutches is in the low part of the range, but still should be high enough?
What should I look at next?
Thanks,
Stephen Kosler
Flatonia, TX
Stephen Kosler
12-06-2006 19:40:24
 Re: looking for a case 2590 powershift guru in reply to stephen kosler, 12-06-2006 15:07:06
I can see where your going with that reply, but I just can't make the mechanical connection. How does the pto affect anything in the P/S? The pto shaft runs through the P/S assembly in a hollow tube. In other words, it is totally seperate from the P/S, right? When I get home tomorrow, I will rip the pto clutch out and take a look but, as much as I want that to be the problem (finally, an answer to my prayers), I can't see the connection.
Thanks for your reply
Stephen
430WLPG
12-06-2006 16:08:01
10 to 1 if you pull the pto and look at the base of the clutch drum you will see a fried pto brake, what ever reason the shaft wouldn't go back in caused the problem. Pull the pto and tear down the clutch
