Hey, M.J. Check out this VAC on Ebay
C. Amick
12-05-2006 09:54:46
I would like to have this one for my collection.
mj
12-06-2006 20:18:32
 Re: Hey, M.J. Check out this VAC on Ebay in reply to C. Amick, 12-05-2006 09:54:46
third party image
Yeah! Thanks for the heads up! Too bad he's about 1K miles from me. Oh well....how about this '51 (with the right front hubs, wheels and tires) for $1,250? It's up and running with the Eagle hitch and all.(S/N 5555381)
Case
12-06-2006 07:52:36
What do you all think about the price and what could be the problem?
C. Amick
12-06-2006 09:14:28
 Re: Hey, M.J. Check out this VAC on Ebay in reply to Case, 12-06-2006 07:52:36
Well, he probably has $600 plus worth of implements with it. The wide front end assembly alone is worth $300. If you could get the whole thing for $1,400 to $1,600, it seems like a good deal. I'm just guessing, but perhaps the shifting linkage has came loose and the tractor is stuck in 4th. gear?
watsonsgotit
12-05-2006 15:05:08
I believe that one is an early 51 due to the position of the lights. Remember the vac was changed mid 51. I wonder why the chain is laying over the front axle?
Jerry W
12-05-2006 13:52:04
Nice tractor. I"ve got one just like it here but I do not believe that it can be a 1952. It is obviously 1949 and newer with the Eagle Hitch but late 1951 VAC"s went to the later styling.
It is possible that some one put an adjustable widefront on a VA or VAI but this one looks original.
Jerry
C. Amick
12-06-2006 05:14:37
 Re: Hey, M.J. Check out this VAC on Ebay in reply to Jerry W, 12-05-2006 13:52:04
Are the wide front VAC tractors any easier to steer? My dad's 1948 narrow front tractor has always required a good bit of effort to turn the wheel.
mj
12-06-2006 20:04:02
 Re: Hey, M.J. Check out this VAC on Ebay in reply to C. Amick, 12-06-2006 05:14:37
third party image
They steer easier than a single or narrow front (the VAO is in 500 lb. gorilla country when it comes to steering!) but with this modification you've got power steering DEluxe!
'Add 3 inches to steering arm as shown by white section. Make sure welds are first rate! This modification, along with a 17" steering wheel (some VAs had 15 inchers), will greatly reduce steering effort.'
Jerry W
12-06-2006 05:29:13
I think they steer a bit easier especially the later ones with the tubular adjustable front that sets back underneath. The earlier I beam front end is much stronger but seems to have a bigger turning radius.
One of the drawbacks is trying to mount any of the front implements - can"t drive into them like with a narrow front.
Jerry
