How much for this tractor?
Kevin5456
12-03-2006 13:50:45
How much would you pay for item # 250056688571 on ebay?
Engineer20
12-03-2006 17:49:25
 Re: How much for this tractor? in reply to Kevin5456, 12-03-2006 13:50:45
I'd say anything running with decent tires and tin would easily bring a minimum of $1000.00
Gene Dotson
12-03-2006 16:22:12
Tractor would bring $1200 in western, Ohio. Sold one very similar last year... Gene
Kevin5456
12-03-2006 16:53:48
 Re: How much for this tractor? in reply to Gene Dotson, 12-03-2006 16:22:12
Stupid question,
Other then pulling what would you use them for? It has no 3pt?
Gene Dotson
12-03-2006 20:13:03
 Re: How much for this tractor? in reply to Kevin5456, 12-03-2006 16:53:48
The standard tractors were used mainly in the wheat growing areas and pulled drawn equipment such as plows, disc tillers and drills. The D was a very easy tractor to get on and off and with the hand clutch, you don't have to shift into neutral when stopping. It is a nice tractor for cutting and raking hay and for pulling wagons.
Lack of a 3 point hitch certainly doesn't restrict the utility of a tractor... Gene
Kevin5456
12-04-2006 06:34:53
 Re: How much for this tractor? in reply to Gene Dotson, 12-03-2006 20:13:03
Thanks for the help,
I should have clarified myself by saying work related.
C. Amick
12-04-2006 09:54:30
 Re: How much for this tractor? in reply to Kevin5456, 12-04-2006 06:34:53
I have non - 3 pt. hitch tractors that I use regularly. This tractor would run a 6 ft. pull type rotary mower. It would also rake and bale hay. You could also pull a set of trail type plows and a trail type disc with it. I use my non - 3pt. hitch tractors for all of the above.
Engineer20
12-03-2006 17:50:55
We really don't need a reason to have an old tractor do we? ;)
Doc Larry
12-03-2006 18:14:23
 Re: How much for this tractor? in reply to Engineer20, 12-03-2006 17:50:55
You meant, we don"t really need a reason to have ANOTHER old tractor, right? :)
Joe C
12-03-2006 18:53:23
 Re: How much for this tractor? in reply to Doc Larry, 12-03-2006 18:14:23
The same reason we climb mountains, because we can...
mj
12-03-2006 20:39:56
 Re: How much for this tractor? in reply to Joe C, 12-03-2006 18:53:23
and there are millions of them out there!
