hydraulic leak from breather for 430
kdok44
12-03-2006 09:35:44
Hello does anyone know what would cause the hydraulic oil to leak out of the breather. It is quite cold here and i noticed this morning that there was hydraulic oil coming from the breather it is quite thick like a milk shake and there was probably a half a quart or so any ideas would be appreacieated thanks.
BarryfromIA
12-03-2006 12:19:01
 Re: hydraulic leak from breather for 430 in reply to kdok44, 12-03-2006 09:35:44
Might be time to pull the dipsticks and see were the fluid levels are. The piston for the three point may be leaking, and you have kept the hydraulic resevior full but did not know where it was going. Well now you have found it. The late model ones had a way of catching this leakage and draining it back to the front gear box. I guess Case could not figure a way make it leak proof.
J Heitkemper
12-04-2006 16:15:44
 Re: hydraulic leak from breather for 430 in reply to BarryfromIA, 12-03-2006 12:19:01
Barry ,,I agree with you ,,The 3 pt ram seals are bad and leaking 30 weight into the rearend ,, Dave in Minn , has similar problem and wondered about drilling a return hole so as to share a common sump ,,I do Believe in fixing things right ,,but I further acknowledge the Cold Climate and Low useage times,About the time shes warmed up the JoB is DONE ,,!RIGHT ? ,and could see hole drilling as forgivable ,PLEASE KNOW ,You can fix the seals in a couple Hours and 60 bucks ,,Mine took longer ,,BUT I DO NOT CARE FOr shop work ,,Good Luck ,,Jim,
BarryfromIA
12-03-2006 12:24:17
You did not say if it was the front or the rear breather. The rear one would be the tranny overfull, also may be oil driping from brakes.
kdok44
12-03-2006 13:14:14
 Re: hydraulic leak from breather for 430 in reply to BarryfromIA, 12-03-2006 12:24:17
hello well the breather is the highest part of the frame near where the frontend loader pivot point is there is a petcock about a foot down from there to check the level so its almost like i have to much in there but i havent added any and last time i checked it was right at the petcock meaning it was correctly filled my neighbour said its probably just frozen up a bit and to buy a magnet heater and put it on the resivior to melt it back to liquid its about -30 and i dont have a heated space.
BarryfromIA
12-03-2006 16:30:42
 Re: hydraulic leak from breather for 430 in reply to kdok44, 12-03-2006 13:14:14
I beleive you are talking about a 430 CK with a utility type loader on it a with a front pump and frame reservior. Years ago when I was a young man doing construction work. They had one that would foam up an run over like that.If we let it warm up some it was not as bad. There might be an anti foaming agent you can buy to add now a days.
Doc Larry
12-03-2006 19:27:07
 Re: hydraulic leak from breather for 430 in reply to BarryfromIA, 12-03-2006 16:30:42
I"m not familiar with this particular model but you likely have a mesh filter on the suction side of the pump. When the oil is cold and thick the filter is restricting the flow so you are either sucking air or cavitating, which is foaming your oil. Warming the oil should help, I"d also check the screen to see if it"s clogged at all. The other options are thinner oil or waiting till spring. We ran very thin "ice machine" oil in hydraulics when I was in the cold country.
Larry
kdok44
12-04-2006 04:45:49
 Re: hydraulic leak from breather for 430 in reply to Doc Larry, 12-03-2006 19:27:07
yes i should have mentioned that is a utility tractor that sounds like my problem i think i will get thinner oil and try the magnet with a heather to get it melted down this is the first time this winter its done this Thanks for all the help this fourm is very helpfull
