Fuel pressure gauge needed
John Rokke
12-02-2006 20:49:34
I'm hoping someone can lead me in the right direction. I need a fuel pressure gauge for a 600 Case diesel, either NOS, good used, or a reproduction will do. Thanks in advance for the help!
Jim B.
12-04-2006 18:25:52
 Re: Fuel pressure gauge needed in reply to John Rokke, 12-02-2006 20:49:34
If you want original equipment, look and fit, you will need to go to a salvage yard. Case does have em'm anymore. I tried for several years from my dealer. I just got a used one for my 2470 at Worthington Ag Parts, $20. 800-248-9263. Worthington has 11 stores in the midwest. The one closest to me is St. Johns MI. Their parts counter computer didn't show any stock, which is not unusual for nickle-dime parts, we went out into the yard and found several and they removed it on-the-spot. I suspect if you get a salesman who's willing to walk outside they may have most anything you need. Most likely, the same gage was used on several models within the era of your tractor so don't limit your question to just your model.
dp in nd
12-03-2006 15:53:34
I am not up on Cases, Why do you need a fuel pressure gauge?Dale
DurangoCase
12-04-2006 07:50:27
 Re: Fuel pressure gauge needed in reply to dp in nd, 12-03-2006 15:53:34
I like a fuel pressure gauge on my diesel to see when my filter is pluged.
Don Livingston
12-03-2006 06:11:20
Call me. 507 433 0073 b4 noon best
Don L.
Roger300
12-03-2006 04:32:47
I often check ebay for "Stewart Warner gauges"
and see Fuel pressure gauges on there. You might want to give it a try .Roger
