SC oil leak
Ralf from MI
12-02-2006 16:12:30
Picked up this nice little SC, as we run it around it has oil driping from around the starter. I opened the drain plug on the right side and got about a third of a cup of oil out. When I got the tractor I changed the oil and drained the clutch housing (plug on right side) as the book says. Am assuming this has to be engine oil and the rear seal is leaking. Dose anyone know what type of seal this is and what has to be done to repair or correct this?
John Saeli
12-02-2006 17:02:17
 Re: SC oil leak in reply to Ralf from MI, 12-02-2006 16:12:30
Hey Ralf: Been trying to e-mail you , but they come bouncin back. H20 pump kit is $49.00. We also stock the starter gasket. Shoot me your phone # & I'll give you a shout. Our phone & fax is 315-585-9826. If we are out, the fax picks up.
John
Dennis Swanson
12-02-2006 16:26:58
Ralf, the oil in the clutch housing is normal due to the fact that the SC has a wet clutch and is lubricated by the crankcase oil. The leak around your starter is caused by a bad or missing cork gasket that fits between the starter and engine block.
