Plow ID?
BobV
12-02-2006 13:50:41
I need the help of you Case technical experts on a plow on Ebay, Item 110062063853 I want to find out the model and size 14" or 16" whats the year, would this be a Case Eagle hitch? I'm looking for a Eagle Hitch 2/16 plow is why I'm asking all of you, any info would help.
BobV
12-03-2006 13:36:59
 Re: Plow ID? in reply to BobV, 12-02-2006 13:50:41
Thanks to you both, I can always depend on people like you to step up with the answers.
charley hellickson
12-03-2006 00:31:09
Hi Bob. That plow is a case model C. I can't tell you the exact model without my book but it is a C and some other letter. The model before this one was a BE, E for eagle hitch. I have one, a 3 14. This plow has Case's best EX bottoms. On the back of the moldboard it will be stamped EX14 or EX16 for size. It also has the trip bottoms, kick back when you hit something. That rod sticking up behind, above the bottom,is the adjuster for the trip preasure. It is a Eagle Hitch. The hitch bar pivots in the center so plow will streer with the ridgid eagle hitch. It is a good looking plow. I was told the model C came out with the 800 tractors which would be 1958, dodn't know how long the were made. I have a 3X16" CH pull plow. It is like this one but doesn't have trip bottoms. It is also the throw away lays. Hope this helps. Charley.
Roger H
12-02-2006 19:36:40
I'm not 100% sure but it looks like a B series plow click on the "ask seller a question" link & ask him what is stamped on the back of the moldboards, should be something like E16 or EX16 if it's a 16 inch. It sure looks like an Eagle Hitch setup. The moldboards look like they don't have a lot of wear on them either.
