Stalling case 430
kdok44
12-02-2006 05:02:29
Hi i was pushing snow this morning and it went good for about an hour. And then it just stalled under light load, started it up and was easy to start and then several more times it just wanted to quit seemed to have something to do with the throttle control usually it likes to be close to full throttle but today it wanted to run more around half or so its a 1969 case 430 gas and its about -30c here at the moment maybe my gas is freezing up if anyone has any ideas let me know. Also when i plug it in my temp goes to about 150 but as i use it, in the cold its stays only around 100 would that effect it Thanks for any help.
Tom (Ks)
12-02-2006 15:25:29
 Re: Stalling case 430 in reply to kdok44, 12-02-2006 05:02:29
You could have some ice forming in the outlet in the fuel tank. I would check that out first. You might put in some HEET in the fuel tank to make sure water will not cause any problems. Around here, people put cardboard in front of the radiator to help it warm up. You could have a bad thermostat too.
kdok44
12-03-2006 09:32:26
 Re: Stalling case 430 in reply to Tom (Ks), 12-02-2006 15:25:29
good idea with the cardboard i think i ll try that i fixed the problem the float was frozen and the carb got filled to much and it was flooding engine i noticed later the carm was dripping from the choke swivel and theres a little spot on bottom of carb that will drip it it gets to full from the air intake part i guess so that if that happens the gas will not eventually fill the engine... anyways thanks for the ideas this is the time of year everything breaks we havent had snow like this since the 1940's lol
