case-o-matic
Tom Brownell
12-01-2006 21:33:37
Ok you case-0-matic people, I've gotten a little help on this forum, now I need some more. I just bought a 1959 614B Grove. (very rare, It's not even listed in most of the books) It has a lever on the right of the steering wheel that is a range selector. That lever has three positions. Does that mean that this tractor is a tripple range tractor or does the middle position have something to do with the case-o-matic? I think the small lever to the left of the wheel is the direct drive/case-o-matic selector. Tom
rongrong
12-02-2006 17:52:06
 Re: case-o-matic in reply to Tom Brownell, 12-01-2006 21:33:37
tom, is a regular tractor or a converted forklift? i have a 610b tractor and in my operaters manual the caseomatic did not come with the triple range transmission. on mine,directly below the steering wheel are two levers the left one is the throttle and the right one is for the caseomatic, pushing it up puts in caseomatic,pulling it down puts it in direct drive. when you have the right lever in direct , stepping on the clutch should move the lever up. as far as transmissions go ,a 4speed ,8 speed, or a shuttle 8 speed was available. if you have a lever on the left side of the trans just above the clutch pedal you have the shuttle trans,just forward of the gear shift lever if you have a lever you have the dual range trans if you have both you have the shuttle.. also the pto should have a lever below the seat to engage it, the pto is live when the engine is running, and is controlled by this lever.
Tom Brownell
12-02-2006 20:11:45
 Re: case-o-matic in reply to rongrong, 12-02-2006 17:52:06
Hey thanks guys! Nope, it's a grove tractor. There was only 106 of these tractors made, and only in 1959. The only book that lists it is the antque Case Tractor Buyer's Guide. It's a 614B Grove. I think that I finally have it figured out!! The range lever has High, Low and neutral. and the other lever just switches from c-o-m to direct drive. I just got a 183 page service manual in the mail today. The direct drive is supposed to be for long heavy pulling and c-o-m is for lite work. If c-o-m is used for things like plowing (heavy pulling) the drive line gets too hot. I'll know more after studying
the manual a little more. Thanks again
Tom
SHeiserman
12-02-2006 12:56:37
Not sure what other, if any, differences there are between yours and mine, but on mine ('67 830) both levers are to the left of the steering column. The lever nearest the column is the range selector, high range is the upper position, start is the middle with low range being the bottom.
Once it's started, I have to clutch to get it in either high or low before taking off. The 2nd lever is the com/direct, and clutching isn't required between those two unless you're taking off or stopping.
Tom Brownell
12-02-2006 10:55:24
Thanks DK, the neutral makes sence since the c-o-m should be disengaged in order to run in direct drive. Don"t know why that didn"t dawn on me!!
DKase
12-02-2006 06:48:40
I have a friend that has a 600 orchard. It has been several years since I drove it, but I remember it as a hand clutch c-o-m. It was very strange to drive. I do not remember where all the levers were. I have never heard of a triple range c-o-m. If it is a late model 600, the range selector would be high, neutral, and low.
mikes600
12-02-2006 06:19:24
is the 3 range sector on the transmission or steering column?
Tom Brownell
12-02-2006 06:43:31
 Re: case-o-matic in reply to mikes600, 12-02-2006 06:19:24
Hi Mike.
The range selector is actually mounted on a bracket by the steering column, and a rod goes under the hood somewhere. My tractor is a 614B Grove tractor and everything is placed further back by extention rods. I know that the righthand lever is the range selector, I'm just not sure if mine is an 8 speed or a 12 speed. From what info I can gather, Case made both. When I bought it, I thought that the center position was the direct drive. However, if the direct drive is on the left of the steering, then what is the center position on the right hand lever?
Tom
Jim B.
12-04-2006 18:36:13
 Re: case-o-matic in reply to Tom Brownell, 12-02-2006 06:43:31
Are you sure the right hand lever is not the control for a power-shuttle, reverser? As was suggested in an earlier post. Case backhoe/loaders with power shuttle have a three position lever... forward, neutral, reverse.
