Case 1370 brake bleeding
Oliver1800A
12-01-2006 10:47:10
I have a 1370 that the left brake seems to have gotten air in it and I need to bleed it out or the brake cylinder is bad. However, I do not see a bleed screw location as the operators manual indicates above the right axle. Also, the steering squeals when turning from the air as well. How do you bleed the two of these or does one procedure handle both. Thanks in advance for the help and suggestions.
dwag
12-01-2006 20:13:17
 Re: Case 1370 brake bleeding in reply to Oliver1800A, 12-01-2006 10:47:10
Bleeders are located on top of rear end housing next to where axle housings bolt on.(follow brake lines to them) Run tractor 12\1500 rpm and loosen one bleeder (1/4" wrench) at a time, no need to pump brake pedals. Steering sounds like low press or splndles binding\need greased.
