Case 530 CK-1949?
Bob Greeley
11-29-2006 16:54:02
Would anyone know the gross weight of this machine?With backhoe and front end loader and without? Much thanks-Bob..
George S. in the real NY
11-30-2006 17:44:18
 Re: Case 530 CK-1949? in reply to Bob Greeley, 11-29-2006 16:54:02
530CK's were built in the '60s. Weight with #32 loader and #32 Hoe is just over 10,000# per the operator's manual. Can't recall the weight of the tractor only, it is in the manual but I'm at work now. HTH
Bob Greeley
12-01-2006 09:32:31
 Re: Case 530 CK-1949? in reply to George S. in the real NY, 11-30-2006 17:44:18
HTH-interesting-another person said the total weight was 8,000 pounds, with all.
If you have the time, can you send me info on backhoe and bucket? Before I pick this up, I'd like to know correct weights-thanks-Bob..
12-01-2006 20:41:23
 Re: Case 530 CK-1949? in reply to Bob Greeley, 12-01-2006 09:32:31
Here are the numbers out of the manual for the loader and hoe. Tractor with loader is: low of 5375 #(gas and dry clutch) to 5725# (diesel with torque converter). This includes the D13022 bucket and NO counterweight. With the #32 hoe on unit, gas/dry clutch is 8645# and diesel with TC is 8995#. My 10,000 was high but it is over 8000. Didn"t mean to scare you or take issue with other posts. It has been awhile since I looked at the data. Basically, if you can comfortably haul 10,000 then this should be OK. More than I would want behind a pickup. Hiring equipment movers to move big stuff is money well spent as if anything goes bad on the road, they have to deal with the bears. I have a D-8 with blade and ended up hiring the move done. They had permits, wide load signs, flashing lites on the truck and their insuance. $300. to move about 40 miles but it was all done in 3 hrs. If it helps, get back to me and I can give you the name of the firm that did that move. They operate over much of the east half of US. George
Bob Greeley
12-02-2006 09:31:28
 Re: Case 530 CK-1949? in reply to George S. in the real NY, 12-01-2006 20:41:23
George-this is great info-I really appreciate your help-I am moving this item from Kansas to Colorado for restoration (app: 700 miles).
Interesting-I have another person waiting for your info-he is moving one from Michigan and needs the weights also.
You have bee a great help,George-thank you very much-Bob...
chvet73
11-30-2006 08:22:29
The whole package is about 8000#. I don't know about it in parts.
Bob Greeley
12-01-2006 11:24:17
 Re: Case 530 CK-1949? in reply to chvet73, 11-30-2006 08:22:29
Hate to be a pest,but George S. in the real NY (message)states this machine totaled is 10,000 pounds-I have to pick this up in three weeks and would like to know exactly what weight this is-do you still think this is 8,000 pounds?Bob...
Bob Greeley
11-30-2006 08:34:36
Thank you very much for info-Bob...
dctom
11-29-2006 17:29:33
dont know the weight but it cant be 49, hast to be 60 or newer
Bob Greeley
11-30-2006 08:35:48
 Re: Case 530 CK-1949? in reply to dctom, 11-29-2006 17:29:33
Thanks for info-Bob...
